giúp khử nhiễu cho 89c51
  • pass74
    Thành viên mới
    • Feb 2009
    • 7
    Mình đang học 8051(Tự học theo cuốn 8051 cơ bản). viết chương trình quét led matrix cho 89s51:
    #include <REGX51.H>
    /*cot tu P0.0 den P0.7
    Hang tu P2.0 den P2.7
    De quet dua ra muc logic 0 lan luot ra cong 0*/
    /*Ham tre*/
    void delay(long time)
    long n;
    for(n=0;n<time;n++)
    unsigned char kytu1[9];//Mang 9 phan tu chua gia tri cac hang day ra cong 1
    unsigned char k=0;//Bien xac dinh cac ki tu
    /* ham nap gia tri hien thi cac ki tu vao mang kytu1
    co 8 dua ra va 1 gia tri khong bat den nao de cac ki tu cach nhau 1 cot*/
    void mahoa(unsigned char x)
    switch(x)
    //dau trang
    case 0:{kytu1[0]=0x00;kytu1[1]=0x00;kytu1[2]=0x00;kytu1[3]=0x00;kytu1[4]=0x00;kytu1[5]=0x00;kytu1[6]=0x00;kytu1[7]=0x00;kytu1[8]=0x00;
    break;}
    // chu M
    case 1:{kytu1[0]=0x00;kytu1[1]=0xFF;kytu1[2]=0x02;kytu1[3]=0x04;kytu1[4]=0x08;kytu1[5]=0x04;kytu1[6]=0x02;kytu1[7]=0xFF;kytu1[8]=0x00;break;}
    //chu T
    case 2:{kytu1[0]=0x00;kytu1[1]=0x01;kytu1[2]=0x01;kytu1[3]=0x01;kytu1[4]=0xFF;kytu1[5]=0x01;kytu1[6]=0x01;kytu1[7]=0x01;kytu1[8]=0x00;
    break;}
    // chu C
    case 3:{kytu1[0]=0x00;kytu1[1]=0x7E;kytu1[2]=0x81;kytu1[3]=0x81;kytu1[4]=0x81;kytu1[5]=0x81;kytu1[6]=0x42;kytu1[7]=0x00;kytu1[8]=0x00;
    break;}
    //dau trang
    case 4:{kytu1[0]=0x00;kytu1[1]=0x00;kytu1[2]=0x00;kytu1[3]=0x00;kytu1[4]=0x00;kytu1[5]=0x00;kytu1[6]=0x00;kytu1[7]=0x00;kytu1[8]=0x00;
    break;}
    /* ham quet led ma tran vua hien thi vua dich ki tu dan sang trai*/
    void hienthi(void)
    unsigned char n,m,lap;
    unsigned char cot[8]={0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F};//cac phan tu quet cot
    for(m=0;m<20;m++)//dich hien thi
    for(lap=0;lap<12;lap++)//lap hien thi
    for(n=0;n<8;n++)//quet cot
    if((n+m)<9)//neu n+m<9 hien thi ky tu 1
    mahoa(k);//nap cac gia tri ma hoa ki tu dua ra cac hang(cong 2)
    P0=cot[n];//day cac gia tri cac hang (ma hoa ki tu) ra cong 2(cac hang)
    delay(100);//tre du de led sang
    if((n+m)>7)//neu n+m>7 hien thi ki tu 2
    mahoa(k+1);//nap gia tri ma hoa ki tu tiep de dua ra cac hang(cong 2)
    P0=cot[n];//day gia tri lo gic 0V ra cong 0 (cac cot)
    P2=kytu1[n+m-8];//day cac gia tri cac hang (ma hoa ki tu) ra cong 2 (cac hang)
    delay(45);//tre du de led sang
    P0=0xFF;//day cac cot len cao
    P2=0x00;//dua cac hang xuong thap de tat toan bo led
    void main(void)
    while(1)//vong lap vo han
    hienthi();//hien thi 2 ki tu dau trang va chu M
    k=k+1;//tang k de hien thi chu M va chu T tiep theo
    if(k==4)k=0;//quay vong hien thi
    Khi mô phỏng bằng proteus7 thấy ngoài các chữ M, T, C hiển thị còn có một số đèn Led sáng không theo lập trình. vậy có phải do nhiễu ko? sửa nhiễu đó bằng cách nào? giúp mình với!
  • pass74
    Thành viên mới
    • Feb 2009
    • 7
    hình ảnh mô phỏng proteus
    • pass74
      Thành viên mới
      • Feb 2009
      • 7
      hình ảnh mô phỏng proteus: Click image for larger version
      • pass74
        Thành viên mới
        • Feb 2009
        • 7
        #4
        không ai trả lời mình sao? đối với các bạn có thể chỉ cần vài phút để phát hiện ra lỗi, nhưng đối với mình thì là cả vấn đề lớn đấy.sai ở phần lập trình hay là sai ở chương trình mô phỏng proteus? giúp mình đi nhé. mong hồi âm sớm của các bạn.
        • tuangia1961
          Thành viên mới
          • Dec 2008
          • 11
          #5
          Không có nhiễu đâu
          mình không quen c theo mình bạn viết quét không có thời gian trễ để led kịp sáng nên dữ liệu sau đè nên
          dữ liệu trưpcs thôi ; mỗi lệnh quét ra bạn cho trễ 1ms là ổn
          • tranthanh78
            Thành viên mới
            • Aug 2010
            • 14
            #6
            Mình không quen dùng C. Nhưng bạn thử làm theo cách này xem. Sau động tác xuất dữ liệu vào hàng hoặc cột, gọi delay, bạn cho dữ liệu =0 (hoặc =0FFh). sau đó mới quét tiếp.
            • hoangdai
              • Nov 2005
              • 2720
              #7
              Muốn nhìn đc thì trễ 1->2ms( Có đc nhờ phép tính 24h/s hoặc lân cận giá trị đó ). Cần phải chống bóng ma nữa mới đầy đủ đc.
              pass74 Tìm hiểu thêm về pass74
