mình nữa annhandt09@gmail.com
Mạch sao băng dung 89cxx
This topic is closed.
wood
sao ban ko lam chay qua chay lai luon.Nguyên văn bởi trungdt_1991 Xem bài viếtMình vừa làm xong mạch sao băng dùng 89c52 , bạn nào muốn làm thì đưa địa chỉ email
lên mình gửi cho.
minh thay chay qua chay lai rat dep ma.
#include <REGX51.H>
unsigned char led[16]={255,250,150,90,30,15,12,8,6,4,4,1,1,0,0,0};
void delay_ms(unsigned int mmmmmsssss,tttttaaaaa){
//65535ms 9000MHz
while(mmmmmsssss--){
unsigned int xxxxxxxxxx = 7*tttttaaaaa+1;
while(xxxxxxxxxx--);
/*xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx*/
/*void delay(unsigned long t)
unsigned int m;
for(m=0;m<t;m++);
unsigned char dem=0,nho;
/*xxxxxxxxxxxxxxx*/
void Timer0()interrupt 1 {
TF0=0; TR0=0;
//if(dem==0) {P0=0;P2=0;}
if(dem>=led[0]) P0_0=0; else P0_0=1;
if(dem>=led[1]) P0_1=0; else P0_1=1;
if(dem>=led[2]) P0_2=0; else P0_2=1;
if(dem>=led[3]) P0_3=0; else P0_3=1;
if(dem>=led[4]) P0_4=0; else P0_4=1;
if(dem>=led[5]) P0_5=0; else P0_5=1;
if(dem>=led[6]) P0_6=0; else P0_6=1;
if(dem>=led[7]) P0_7=0; else P0_7=1;
if(dem>=led[8]) P2_7=0; else P2_7=1;
if(dem>=led[9]) P2_6=0; else P2_6=1;
if(dem>=led[10]) P2_5=0; else P2_5=1;
if(dem>=led[11]) P2_4=0; else P2_4=1;
if(dem>=led[12]) P2_3=0; else P2_3=1;
if(dem>=led[13]) P2_2=0; else P2_2=1;
if(dem>=led[14]) P2_1=0; else P2_1=1;
if(dem>=led[15]) P2_0=0; else P2_0=1;
dem++;
TR0=1;
/*xxxxxxxxxxxxxxx*/
/*void Timer1()interrupt 3 {
TF1=0; TR1=0;
if(dem>=led[15]) P0_0=0; else P0_0=1;
if(dem>=led[14]) P0_1=0; else P0_1=1;
if(dem>=led[13]) P0_2=0; else P0_2=1;
if(dem>=led[12]) P0_3=0; else P0_3=1;
if(dem>=led[11]) P0_4=0; else P0_4=1;
if(dem>=led[10]) P0_5=0; else P0_5=1;
if(dem>=led[9]) P0_6=0; else P0_6=1;
if(dem>=led[8]) P0_7=0; else P0_7=1;
if(dem>=led[7]) P2_7=0; else P2_7=1;
if(dem>=led[6]) P2_6=0; else P2_6=1;
if(dem>=led[5]) P2_5=0; else P2_5=1;
if(dem>=led[4]) P2_4=0; else P2_4=1;
if(dem>=led[3]) P2_3=0; else P2_3=1;
if(dem>=led[2]) P2_2=0; else P2_2=1;
if(dem>=led[1]) P2_1=0; else P2_1=1;
if(dem>=led[0]) P2_0=0; else P2_0=1;
dem++;
TR1=1;
/*xxxxxxxxxxxxxxxxxxxxx quay phai xxxxxxxxxxxxxxxxxxxxx*/
void main(void)
while(1)
unsigned int i,j,k;
TH0=180;
TL0=180;
TMOD=0x02; //timer 0: che do 2: 8 bit tu dong nap lai
EA=1; ET0=1; TR0=1;
for(i=1;i<500;i++)
delay_ms(15,10); dem=0;
nho= led[0];
led[0]= led[1]; led[1]= led[2]; led[2]= led[3]; led[3]= led[4];
led[4]= led[5]; led[5]= led[6]; led[6]= led[7]; led[7]= led[8];
led[8]= led[9]; led[9]= led[10]; led[10]=led[11]; led[11]=led[12];
led[12]=led[13]; led[13]=led[14]; led[14]=led[15]; led[15]=nho;
/*xxxxxxxxxxxxxx quay phai xxxxxxxxxxxxxxxxxxx*/
/*TR0=0;
TH1=180;
TL1=180;
EA=1; ET1=1; TR1=1;*/
for(j=1;j<500;j++)
nho= led[15];
led[15]= led[14]; led[14]= led[13]; led[13]= led[12]; led[12]= led[11];
led[11]= led[10]; led[10]= led[9]; led[9]= led[8]; led[8]= led[7];
led[7]= led[6]; led[6]= led[5]; led[5]=led[4]; led[4]=led[3];
led[3]=led[2]; led[2]=led[1]; led[1]=led[0]; led[0]=nho;
/*xxxxxxx chop tat xxxxxxxxxxxxxxxxxxxxxxx*/
TR0=0;
for(k=1;k<20;k++)
P0_0=0;
P0_1=0;
P0_2=0;
P0_3=0;
P0_4=0;
P0_5=0;
P0_6=0;
P0_7=0;
P2_7=0;
P2_6=0;
P2_5=0;
P2_4=0;
P2_3=0;
P2_2=0;
P2_1=0;
P2_0=0;
delay_ms(60,30);
P0_0=1;
P0_1=1;
P0_2=1;
P0_3=1;
P0_4=1;
P0_5=1;
P0_6=1;
P0_7=1;
P2_7=1;
P2_6=1;
P2_5=1;
P2_4=1;
P2_3=1;
P2_2=1;
P2_1=1;
P2_0=1;
delay_ms(60,30);
89c52
gưi cho mình nhớ.thank youNguyên văn bởi trungdt_1991 Xem bài viếtMình vừa làm xong mạch sao băng dùng 89c52 , bạn nào muốn làm thì đưa địa chỉ email
lên mình gửi cho.
:truongvanly.hn@gmail.com
uhm....anh nao biếtlooixx báo nhu vầy thì pm giùm nha....http://seablogs.zenfs.com/u/jpLyoKWc...34.jpg....cái orcad của em khi chuyển từ CAptur sang LAyout là bị như vậy á ai biết thì chỉ em với.......nguyen_thanh_phong_9009@yahoo.com.vn
hôm nay, 09:21 -
hôm nay, 09:09 -
bởi theidiotcatKhi ráp một bộ máy tính cấu hình cao, việc cân đối ngân sách cho từng linh kiện là rất quan trọng. Sự kết hợp giữa vi xử lý AMD Ryzen thế hệ mới có công nghệ 3D V-Cache và card đồ họa Radeon RX 9070 XT đang là lựa chọn rất đáng tiền....
11-06-2026, 10:43 -
Trả lời cho Yêu thơ mê nhạc, mời các bác vào đây!bởi dinhthuong92Giới thiệu bản nhạc đệm mới nhộn nhịp tươi vui, nghe là muốn... xuất gia đi tu liền!!!!😁...
11-06-2026, 09:51 -
Trả lời cho Máy đo khuôn mẫubởi vi van phamQuá dễ, Mua cái máy xq quét tòan thân, lấy bàn và khung di chuyển. Tháo đầu xquang ra bán ve chai, mua cái máy siêu âm gắn vào vị trí đầu đèn. Setup máy là chạy chính xác, còn file Setup thì chưa nghĩ ra....
Channel: Đo lường và điều khiển dùng máy tính
07-06-2026, 08:49 -
Trả lời cho Máy Phun sương tạo ầm Trung Quốc.bởi nguyendinhvanMạch tạo sương là tự dao động.
Mach 555 là đóng mở chu kỳ tần số thấp.
IC 555 giá rẻ, chỉ chạy lên tần số vài trăm ki lô hẹc thôi. Thăng cao hơn là méo dạng rồi tịt.
Mach sương thì dao động tần số tầm 2 mê ga hẹc cơ !...-
07-06-2026, 00:09 -
Cái máy đo này mắc tiền quá !
Anh em dtvn có giải pháp nào tự chế được không ?...-
07-06-2026, 00:00 -
bởi nguyendinhvanOi giời.
Thơi buổi PLC rồi, cậu còn hỏi mấy thứ cổ lỗ sĩ này nữa.-
06-06-2026, 22:59 -
bởi nguyendinhvanChuyện này cũ rồi.
Họ trả lương cho CN, sau đó lại bán hàng thu tiền về. Họ còn cấp các dịch vụ như chỗ ăn ở, quán cafe , giải trí, phương tiện giao thông. Mục đích là thu tối đa số tiền đã chi trả.
Hàng hóa sx ra, chuyển...-
Channel: Tìm mua
06-06-2026, 22:56 -
Trả lời cho Yêu thơ mê nhạc, mời các bác vào đây!bởi vi van phambao nhiêu năm quên bẳng đi, là mình còn có 1 chút xíu nghệ thuật bài bản, đã dạy cho con cháu chơi đàn, dù bố mẹ và chúng không xem là quan trọng. Hôm qua ngày bế mạc lớp lá, bỗng dưng thằng cháu ngoại thấy con bé được sơ giới thiệu...
06-06-2026, 21:58 -
