các bác sửa dùm e code 89c51 với ds1620
  • dtvtk27c
    Thành viên mới
    • Feb 2011
    • 7
    không biết em viết code sai ở đâu mà không hiển thị nhiệt độ được với ds1620. các bác xem jup em. xem sai ở chỗ nào nhé. e đang làm đồ án cần lắm. các bác sửa jup e nhé. thank các bác nhiều.
    /************ chuong trinh hien thi nhiet do
    su dung at89c51
    ds1620
    #include <REGX51.H>
    unsigned char code7seg[10]={0xC0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x9 0};
    sbit ds1620_dq = P3^0;
    sbit ds1620_clk = P3^1;
    sbit ds1620_rst = P3^2;
    #define read_temp 0xAA // read temp command
    #define start_convert 0xEE // bat dau bien doi
    #define write_config 0x0C // ghi cau hinh
    // ham tre
    void delay(long time)
    unsigned char n;
    for(n=0;n<time;n++)
    void tre()
    unsigned int x;
    for(x=0;x<33000;x++)
    // ghi ds1620
    void write_ds1620_bit(unsigned char b)
    ds1620_dq = b; // gui bit
    ds1620_clk = 0; // clk = 0
    ds1620_clk = 1; // clk = 1
    ds1620_dq = 1;
    // doc ds1620
    unsigned char read_ds1620_bit()
    unsigned char b;
    ds1620_clk=0;
    b=ds1620_dq;
    ds1620_clk=1;
    return(b);
    // ham ghi giao thuc, lenh vao ds1620
    void write_to_ds1620(unsigned char ds1620_function,unsigned char ds1620_data,unsigned char bit_count)
    unsigned char i,this_bit;
    ds1620_rst=1;
    for(i=0;i<8;i++)
    this_bit=ds1620_function>>i;
    this_bit=this_bit & 0x01;
    write_ds1620_bit(this_bit);
    for(i=0;i<bit_count;i++)
    this_bit=ds1620_data>>i;
    ds1620_rst=0;
    // ham doc nhiet do tu ds1620
    unsigned int read_from_ds1620(unsigned char ds1620_function,unsigned char bit_count)
    unsigned char ds1620_data;
    ds1620_data=0;
    ds1620_rst=1;
    for(i=0;i<8;i++)
    ds1620_data=ds1620_data | read_ds1620_bit() <<i;
    ds1620_rst=0;
    return(ds1620_data);
    // ghi cau hinh cho ds1620
    void configure_ds1620()
    write_to_ds1620(write_config,2,8);
    tre();
    // ham bat dau chuyen doi nhiet do
    void start_temp_convert()
    write_to_ds1620(start_convert,0,0);
    // ham doc nhiet do
    unsigned char read_temperature()
    unsigned int t;
    t=read_from_ds1620(read_temp,9);
    return(t);
    // ham hien thi nhiet do len led 7 thanh
    void display_temperature(unsigned char x)
    P2=0x01;
    P0=code7seg[(x%10)];
    delay(100);
    P2=0x02;
    P0=code7seg[(x/10)];
    delay(100);
    // ham chinh
    void main(void)
    unsigned int temp;
    cofigure_ds1620();
    start_temp_convert();
    while(1)
    temp=read_temperature();
    display_temperature(temp);
    tre();
  • lionup06
    Thành viên mới
    • Feb 2012
    • 21
    cái này mình cũng đang làm đồ án 2. con này ở VN tuơng đối mới. mình có nghiên cứu trên mấy diễn đàn nước ngoài code cho 89c52 thì nói chung là mình chưa kiểm chứng mình thấy giải thuật thì đúng còn test thì mình chưa thử... nếu cần thì chúng mình có thể trao đổi nhé
    • gabong412
      Thành viên mới
      • Aug 2012
      • 11
      ai có code lập trình asm cho bài tập : hiển thị dong điện trên LCD dùng 8051 với 0809 không cho mình tham khảo với
      dtvtk27c Tìm hiểu thêm về dtvtk27c
