download từ ieee
Bạn jefflieu!
Mình đang làm đề tài về mạng nơ ron ứng dụng bù công suất phản kháng trong lưới phân phối. Mình rất cần 1 số tài liệu này mong bạn tìm giúp. Thanks so much..
1. Neural Network-Based Selective Compensation of Current Quality Problems in Distribution System
Zhu, J.Z. Chang, C.S. Yan, W. Xu, G.Y.
Dept. of Electr. Eng., Nat. Univ. of Singapore
This paper appears in: Industrial Electronics, IEEE Transactions on
Issue Date: Feb. 2007
Volume: 54 Issue:1
On page(s): 53 - 60
ISSN: 0278-0046
INSPEC Accession Number: 9299031
Digital Object Identifier: 10.1109/TIE.2006.888754
Date of Current Version: 05 February 2007
Sponsored by: IEEE Industrial Electronics Society
link: http://ieeexplore.ieee.org/xpl/freea...number=4084701
2. Reactive power optimisation using an analytic hierarchical process and a nonlinear optimisation neural network approach
This paper appears in: Generation, Transmission and Distribution, IEE Proceedings-
Issue Date : Jan 1998
Volume : 145 , Issue:1
On page(s): 89 - 97
ISSN : 1350-2360
References Cited: 14
INSPEC Accession Number: 5830583
Date of Current Version : 06 August 2002
Sponsored by : IET
link: http://ieeexplore.ieee.org/search/fr...d%3DSearch+All
3. An artificial neural network based application to reactive power dispatch problem
This paper appears in: Electrotechnical Conference, 1998. MELECON 98., 9th Mediterranean
Issue Date : 18-20 May 1998
Volume : 2
On page(s): 1080 - 1083 vol.2
Meeting Date : 18 May 1998-20 May 1998
Print ISBN: 0-7803-3879-0
References Cited: 7
INSPEC Accession Number: 6128103
Digital Object Identifier : 10.1109/MELCON.1998.699398
4. Fast power flow with capability of corrective control using a neural network
This paper appears in: Circuits and Systems, 1992., Proceedings of the 35th Midwest Symposium on
Issue Date : 9-12 Aug 1992
On page(s): 1057 - 1060 vol.2
Meeting Date : 09 Aug 1992-12 Aug 1992
Print ISBN: 0-7803-0510-8
References Cited: 4
INSPEC Accession Number: 4584396
Digital Object Identifier : 10.1109/MWSCAS.1992.271112
5. Modern power system
This paper appears in: Information and Communication Technology in Electrical Sciences (ICTES 2007), 2007. ICTES. IET-UK International Conference on
Issue Date : 20-22 Dec. 2007
On page(s): I-6 - I-6
ISSN : 0537-9989
Date of Current Version : 30 December 2008
4 bài báo đầu đây bạn:
http://www.mediafire.com/?fo5ik7yc3vc31wt
http://www.mediafire.com/?prots12zf7w53az
http://www.mediafire.com/?eq2te724eefiik1
http://www.mediafire.com/?0g8ig43z4ymyh4c
bài báo cuối đây ( chính xác là bài giảng, tới 21 mb
http://www.mediafire.com/?ce2ettd2m0elsr4
2 link bài báo của bạn kkkk ko tìm được!!!==>
bác có thể down giúp tôi mấy paper trên ieee này không? đang rất cần mà không có acc nên down không được mong bác giúp dùm, vô cùng cảm ơn. Bác có thể giúp bao nhiêu được thì giúp. Đang rất rất cần.
[1] J.Z. Zhu, “Multiarea power systems economic dispatch using a nonlinear optimization neural network approach, ”Electric Power Components and System” Vol.31 , 2002, pp. 553 – 563 .
Taylor & Francis publishes knowledge and specialty research spanning humanities, social sciences, science and technology, engineering, medicine and healthcare.
[2] J.Z. Zhu and J.A. Momoh Multiarea power systems economic dispatch using nonlinear convex network flow programming, ”Electric Power Systems, “Research”, Vol. 59, No.1, 2001, pp. 13 – 20 .
http://www.sciencedirect.com/science...7fef08f887c143
1. C.S. Chang, A.C. Liew , J.X. Xu , X.W. Wang , and B. Fan
Dynamic security constrained multiobjective generation dispatch of longitudinally interconnected power systems using bicriterion global optimization
2. D. Streiffert
“Multiarea economic dispatch with tie line constraints ”
IEEE/PES Winter Meeting, 1995, WM 179 - 2.
3. C. Wang and S.M. Shahidehpour
“Power generation scheduling for multi area hydro - thermal systems with tie line constraints, cascaded reservoirs and uncertain data”
IEEE Trans., PAS , Vol. 08 , No. 3 , 1993 , pp. 1333 – 1340 .
4. O. Alsac and B. Stott
“Optimal power flow with steady - state security”
IEEE Trans., PAS , Vol. 93 , 1974 , pp. 745 – 751 .
7. J.Z. Zhu and M.R. Irving, “Combined active and reactive dispatch with multiple objectives using an analytic hierarchical process” IEE Proc. C , Vol. 143 , No. 4 , 1996 , pp. 344 – 352 .
[10] M.R. Irving and M.J.H. Sterling, “Economic dispatch of active power with constraint relaxation ” IEE Proc. C , Vol.130 , No.4, 1983 .
[11] M.R. Irving and M.J.H. Sterling , “ Efficient Newton - Raphson algorithm for load flow calculation in transmission and distribution networks” IEE Proc. C , Vol. 134, 1987 .
[12] J.Z. Zhu and G.Y. Xu, “A new real power economic dispatch method with security, ” Electric Power Systems Research” Vol. 25 , No. 1 , 1992 , pp. 9 – 15 .
http://www.sciencedirect.com/science...1274877876f456
[13] D.C. Walters and Z.C. Sheble, “Genetic algorithm solution of economic dispatch with valve point loading ” IEEE Trans., on Power Systems , Vol. 8 , No. 3 , 1993 .
[14] M. Salami and G. Cain, “Multiple genetic algorithm processor for the economic power dispatch problem” Procs. of Intern. Conf. on Genetic Algorithm in Engineering Systems, UK , Sep., 1995 , pp. 188 – 193 .
[15] T.D. King , M.E. El - Hawary , and F. El - Hawary , “Optimal environmental dispatching of electric power system via an improved Hopfi eld neural network model” IEEE Trans on Power System, Vol. 10 , No. 3 , 1995 , pp. 1559 – 1565 .
http://ieeexplore.ieee.org/xpl/freea...rnumber=466488
[16] K.P. Wong and C.C. Fung , “Simulated - annealing - based economic dispatch algorithm” IEE Proc. Part C , Vol. 140 , No. 6 , 1993 , pp. 509 – 515 .
http://ieeexplore.ieee.org/xpl/freea...rnumber=285164
[17] T.H. Lee , D.H. Thorne , and E.F. Hill , “A transportation method for economic dispatching — Application and comparison” IEEE Trans., PAS, 1980, Vol. 99, pp. 2372 – 2385 .
http://ieeexplore.ieee.org/xpl/freea...number=4114080
[18] E. Hobson , D.L. Fletcher , and W.O. Stadlin, “Network flow linear programming techniques and their application to fuel scheduling and contingency analysis” IEEE Trans., PAS , 1984 , Vol. 103 , pp. 1684 – 1691 .
http://ieeexplore.ieee.org/xpl/freea...number=4112730
[19] A.J. Wood and B.F. Wollenberg, Power Generation, Operation, and Control , Second edition , New York : John Wiley & Sons , 1996 .
[20] K.L. Lo and S.P. Zhu, “A Theory for Pricing Wheeled Power” Electric Power Systems Research , 1994 , Vol. 28 .
http://www.sciencedirect.com/science...b8b44fc4cda5dc
[21] M.C. Caramanis, R.E. Bohn, and F.C. Schweppe , “The Costs of Wheeling and Optimal Wheeling Rates” IEEE Transactions on Power Systems, Vol. PWRS, No. 1 1986 .
http://ieeexplore.ieee.org/xpl/freea...number=4334845
[22] H.H. Happ, “Cost of Wheeling Methodology” IEEE Transactions on Power Systems , Vol. 9 , No. 1 , February 1994 .
http://ieeexplore.ieee.org/xpl/freea...rnumber=317547
[23] Purdue ECE Technical Reports, “Real Time Pricing of Electric Power” 1995, http://docs.lib.purdue.edu/ecetr/120
[24] J.Z. Zhu and C.S. Chang, “Energy transaction scheduling with network constraints and transmission losses” , Proc. of Intern. Conf. On Advances in Power System Control, Operation & Management, APSCOM - 97 , Nov. 11 – 14, 1997 , Hong Kong .
http://ieeexplore.ieee.org/xpl/freea...rnumber=724935
[25] Y.Z. Li and A.K. David , “Optimal MultiArea Wheeling” IEEE Transactions on Power Systems , Vol. 9 , No. 1 , February 1994 .
http://ieeexplore.ieee.org/xpl/freea...rnumber=317599
Anh chị down giúp giùm em bài báo sciencedirect này:
Pitch-synchronous waveform processing techniques for text-to-speech synthesis using diphones
của Eric Moulines, và Francis Charpentier
link
và
Voice transformation using PSOLA technique
của H. Valbreta, E. Moulinesa và J.P. Tubach
link
Cám ơn anh chị rất nhiều.
Bạn có thể tìm gấp hộ mình tài liệu này được không?
http://ieeexplore.ieee.org/xpl/freea...rnumber=661072
Cảm ơn nhiêu nhé.
Chào anh, em đang làm nghiên cứu về vấn đề năng lượng mặt trời tại viêt nam, đang cần một số tài liệu trên IEEE. anh giúp em download bài này nhé :http://ieeexplore.ieee.org/Xplore/lo...hDecision=-203
em cảm ơn!
chào các anh,em đang tìm hiểu về UWB,có tài liệu IEEE cần download mong các anh giúp đỡ http://ieeexplore.ieee.org/xpl/freea...number=1437940
em xin chân thành cảm ơn!
Chào các bạn!
Mình tìm thấy trang web này có giúp đỡ tìm tài liệu trên IEEE, lính mới vừa bước vào nghiên cứu khoa học như mình rất mong được sự giúp đỡ của các bạn, đầu tiên có tài liệu này xin down hộ:
"Fault Tolerance by Design Diversity: Concepts and Experiments"
vizienis, A.; Kelly, J.P.J.;
UCLA Computer Science Department
This paper appears in: Computer
Issue Date: Aug. 1984
Volume: 17 Issue:8
On page(s): 67 - 80
ISSN: 0018-9162
Digital Object Identifier: 10.1109/MC.1984.1659219
Date of Current Version: 24 Июль 2006
Sponsored by: IEEE Computer Society
link: http://ieeexplore.ieee.org/xpl/freea...number=1659219
Email: tarzan_2502@yahoo.com
Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Nhờ các ace download hộ giùm mình tài liệu:
http://ieeexplore.ieee.org/xpl/freea...number=5578915
Xin chân thành cảm ơn các bạn.
maiphuctien@gmail.com
Của các bác nè:
-trieuvd81 : http://www.mediafire.com/?b983qvpyzgc33ey
(sách bạn tìm trên ebookee có đấy, một vài link bị lỗi)
-thegracious: http://www.mediafire.com/?or4uyt0exooduj9
-hoangsex : http://www.mediafire.com/?i4hv7qw0g1nl9tw
-quyenbs :http://www.mediafire.com/?h3qgkgj5xtp995m
-max191989 :http://www.mediafire.com/?s7r7sj6ssv34k9d
-pham20092009 :http://www.mediafire.com/?invvqcglgnn4tgq
-maiphuctien :http://www.mediafire.com/?p9903pkpp3wi2q3==>
Em chào các anh chị!
Em là mem mới gia nhập. Em xin nhờ các anh chị down giúp em tài liệu này ạ. (Em đang cần gấp để đi in)
http://www.computer.org/portal/web/c...9/FSKD.2008.91
An Efficient Fuzzy Kohonen Clustering Network Algorithm
October 18-October 20
ISBN: 978-0-7695-3305-6
Em cảm ơn các anh chị rất nhiều!
Chào các bạn. Mình cũng là mem mới, xin các bạn và anh, chị giúp mình tài liệu này với (Đang cần gấp ạ)
1) "Extended mappings for Bit-interleaved coded modulation" in Proc.of the 17th Annual IEEE international Symposium on Personal, Indoor and Mobile Radio communication 2006
2) Optimization of symbol, mappings for BICM-ID của IEEE
3) bit-interleaved coded modulation with iterative decoding 8psk" IEEE commun.Letters
Nếu anh hay bạn nào download được thì gửi về mail cho em với " moschino_lx26@yahoo.com "
Cám ơn các bạn rất nhiều.
cac anh chi giup em download tai lieu nay' voi.Cám ơn anh chị rất nhiều.
Hôm qua, 14:33 -
Hôm qua, 10:49 -
