Lỗi gán tín hiệu trong khối MUX(VHDL)
  • tri2061990
    • May 2010
    • 9
    Code của em
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    entity mux3 is
    port(
    Sel : in std_logic_vector(1 downto 0);
    Din1 : in std_logic_vector(4 downto 0);
    Din2 : in std_logic_vector(4 downto 0);
    Din3 : in std_logic_vector(4 downto 0);
    Dout : out std_logic_vector(4 downto 0)
    end mux3;
    architecture rtl of mux3 is
    signal s1,s2,s3:std_logic_vector(4 downto 0);
    begin
    s1<=Din1;s2<=Din2;s3<=Din3;
    with sel select
    Dout<=s1 when "01",
    Dout<=s2 when "00" ,
    Dout<=s3 when "10",
    Dout<=s2 when "11",
    Unaffected when others;
    end rtl;
    Lỗi
    # ** Error: mux3.vhd(24): Type error resolving infix expression "<=" as type ieee.std_logic_1164.std_logic_vector.
    # ** Error: mux3.vhd(24): Cannot read output "dout".
    # ** Error: mux3.vhd(25): Type error resolving infix expression "<=" as type ieee.std_logic_1164.std_logic_vector.
    # ** Error: mux3.vhd(25): Cannot read output "dout".
    # ** Error: mux3.vhd(26): Type error resolving infix expression "<=" as type ieee.std_logic_1164.std_logic_vector.
    # ** Error: mux3.vhd(26): Cannot read output "dout".
    # ** Error: mux3.vhd(29): VHDL Compiler exiting
    # C:/Modeltech_6.3f/win32/vcom failed.
    Bác nào giúp em với?
  • Edimark
    • Oct 2010
    • 24
    Em bị sai lỗi cú pháp With signal Select trong VHDL, sửa lại như sau:
    Code:
    begin
    with sel select
    Dout <= s1 when "01",
            s2 when "00",
            s3 when "10",
            s2 when "11",
    end rtl;
    tri2061990 Tìm hiểu thêm về tri2061990
