Giúp sửa lỗi chương trinh viết cho pic16f887
  • chanhmuoi
    • Mar 2014
    • 10
    Em dùng mplab x ide và mplab xc8
    Sẵn cho em hỏi cách đưa code lên diễn đàn, tìm cách post code trong diễn đàn mà chưa thấy.
    Cám ơn mọi người nhiều ạ.
    PHẦN CHƯƠNG TRÌNH
    #include<pic16f887.h>
    #include<xc.h>
    #include<stdio.h>
    #include<stdlib.h>
    // CONFIG1
    #pragma config FOSC = XT // Oscillator Selection bits (XT oscillator: Crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN)
    #pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register)
    #pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
    #pragma config MCLRE = OFF // RE3/MCLR pin function select bit (RE3/MCLR pin function is digital input, MCLR internally tied to VDD)
    #pragma config CP = OFF // Code Protection bit (Program memory code protection is disabled)
    #pragma config CPD = OFF // Data Code Protection bit (Data memory code protection is disabled)
    #pragma config BOREN = OFF // Brown Out Reset Selection bits (BOR disabled)
    #pragma config IESO = OFF // Internal External Switchover bit (Internal/External Switchover mode is disabled)
    #pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is disabled)
    #pragma config LVP = OFF // Low Voltage Programming Enable bit (RB3 pin has digital I/O, HV on MCLR must be used for programming)
    // CONFIG2
    #pragma config BOR4V = BOR21V // Brown-out Reset Selection bit (Brown-out Reset set to 4.0V)
    #pragma= OFF config WRT = OFF // Flash Program Memory Self Write Enable bits (Write protection
    #define _XTAL_FREQ 4000000
    void main (void)
    void port_init();
    void adc_init();
    void in_init();
    while(1){
    __delay_ms(10);
    GODONE = 1;
    void port_init(void){
    ANSEL = 0xO8;
    ANSELH = 0;
    TRISA2 = 1;
    TRISE = 0;
    PORTE = 0xff;
    void adc_init(){
    ADCON0bits.ADCS1 = 0;
    ADCON0bits.ADCS0 = 1;
    VCFG0 = 0;
    VCFG1 = 0;
    CHS3 = 0;
    CHS2 = 0;
    CHS1 = 1;
    CHS0 = 0;
    ADFM = 1;
    ADON = 1;
    __delay_ms(1);
    void in_init(){
    GIE = 1;
    PEIE = 1;
    ADIE = 1;
    ADIF = 0;
    void interrupt IRS(){
    int adc_result;
    if(PIE && ADIE && ADFE){
    if (adc_result> 818)
    PORTE=0b000; //Turn LEDs ON
    else if(adc_result> 613)
    PORTE=0b101;
    else if(adc_result> 409)
    PORTE=0b011;
    else if(adc_result> 204)
    PORTE=0b110;
    PHẦN LỖI
    make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
    make[1]: Entering directory 'E:/dien/nhap_project16f/adc_bai1.X'
    make -f nbproject/Makefile-default.mk dist/default/production/adc_bai1.X.production.hex
    make[2]: Entering directory 'E:/dien/nhap_project16f/adc_bai1.X'
    "C:\Program Files (x86)\Microchip\xc8\v1.34\bin\xc8.exe" --pass1 --chip=16F877 -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/adc.p1 adc.c
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1157 : warning: (111) redefining preprocessor macro "_ADCON0_GO_nDONE_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1248)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1158 : warning: (111) redefining preprocessor macro "_ADCON0_GO_nDONE_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1249)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1161 : warning: (111) redefining preprocessor macro "_ADCON0_GO_nDONE_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1252)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1162 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1253)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1163 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1254)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1164 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_SIZE" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1255)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1165 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_LENGTH" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1256)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1166 : warning: (111) redefining preprocessor macro "_ADCON0_CHS_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1257)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1172 : warning: (111) redefining preprocessor macro "_ADCON0_GO_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1263)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1173 : warning: (111) redefining preprocessor macro "_ADCON0_GO_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1264)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1176 : warning: (111) redefining preprocessor macro "_ADCON0_GO_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1267)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1177 : warning: (111) redefining preprocessor macro "_ADCON0_CHS0_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1268)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1178 : warning: (111) redefining preprocessor macro "_ADCON0_CHS0_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1269)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1181 : warning: (111) redefining preprocessor macro "_ADCON0_CHS0_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1272)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1182 : warning: (111) redefining preprocessor macro "_ADCON0_CHS1_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1273)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1183 : warning: (111) redefining preprocessor macro "_ADCON0_CHS1_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1274)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1186 : warning: (111) redefining preprocessor macro "_ADCON0_CHS1_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1277)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1187 : warning: (111) redefining preprocessor macro "_ADCON0_CHS2_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1278)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1188 : warning: (111) redefining preprocessor macro "_ADCON0_CHS2_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1279)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1191 : warning: (111) redefining preprocessor macro "_ADCON0_CHS2_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1282)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1202 : warning: (111) redefining preprocessor macro "_ADCON0_nDONE_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1298)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1203 : warning: (111) redefining preprocessor macro "_ADCON0_nDONE_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1299)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1206 : warning: (111) redefining preprocessor macro "_ADCON0_nDONE_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1302)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1207 : warning: (111) redefining preprocessor macro "_ADCON0_GO_DONE_POSN" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1303)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1208 : warning: (111) redefining preprocessor macro "_ADCON0_GO_DONE_POSITION" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1304)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:1211 : warning: (111) redefining preprocessor macro "_ADCON0_GO_DONE_MASK" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 1307)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2225 : warning: (111) redefining preprocessor macro "CHS0_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3655)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2227 : warning: (111) redefining preprocessor macro "CHS1_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3657)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2229 : warning: (111) redefining preprocessor macro "CHS2_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3659)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2259 : warning: (111) redefining preprocessor macro "GO_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3709)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2261 : warning: (111) redefining preprocessor macro "GO_DONE_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3711)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2263 : warning: (111) redefining preprocessor macro "GO_nDONE_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 3713)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2591 : warning: (111) redefining preprocessor macro "nDONE_bit" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f887.h: 4213)
    C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2224 : error: (1098) conflicting declarations for variable "CHS0" (C:\Program Files (x86)\Microchip\xc8\v1.34\include\pic16f877.h:2224 )
    (908) exit status = 1
    nbproject/Makefile-default.mk:94: recipe for target 'build/default/production/adc.p1' failed
    make[2]: Leaving directory 'E:/dien/nhap_project16f/adc_bai1.X'
    nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
    make[1]: Leaving directory 'E:/dien/nhap_project16f/adc_bai1.X'
    make[2]: *** [build/default/production/adc.p1] Error 1
    make[1]: *** [.build-conf] Error 2
    make: *** [.build-impl] Error 2
    nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
    BUILD FAILED (exit value 2, total time: 1s)
    Linux zealot
    • Jun 2007
    • 6171
    Chỉ cần duy nhất dòng #include là đủ, bỏ 3 dòng #include còn lại đi. Chú ý có khoảng trắng giữa chỉ thị #include và tên tệp.
    • queduong
      Moderator
      • Jul 2005
      • 6781
      #include <pic16f887.h>
      thế là đủ. #inculde [dấu cách] <tên tệp >
      • chanhmuoi
        • Mar 2014
        • 10
        1. Em cám ơn, e đã sửa được một số lỗi, em đang tự học con pic này, giải thích giúp em tại sao ta phải bỏ 3 dòng lệnh đó vậy, những bài tập trước em làm không bỏ 3 dòng đó chương trình vẫn không bị lỗi.
        2. Chương trình còn 1 số lỗi, khi em nhấp vô nó không báo lỗi ở chương trình mà hiện ra file mới: Makefile-default.mk, Makefile-impl.mk. Chương trình bị sao vậy ạ? Em phải sửa thế nào?
        Em cám ơn mọi sự hỗ trợ của mọi người nhiều ạ.
        • htc2k14
          • Oct 2014
          • 279
          - 2 dòng include cuối của bạn ko cần thiết vì bộ nhớ của PIC nhỏ (ko như PC), ít khi dùng các hàm printf hay scanf...
          - 2 dòng include đầu chỉ cần 1 trong 2, mình thường chọn xc.h. Vì khi bạn setup project đã chọn 1 con PIC, include xc.h có chức năng tương tự như include picxxx.h. Mình thường chọn xc.h, chừng nào trình dịch ko nhận ra con PIC mình sẽ include như 2 bác ở trên.
          - Hồi trước cũng gặp lỗi này, check con PIC cũng ko phải PIC mới. Bạn thử cài compiler cũ hoặc mới hơn xem thế nào.
          - Còn về chương trình, nhìn vào hàm ngắt thì thấy chắc khó mà chạy đúng như ý muốn, cái này fix từ từ bằng code sau
          - Cái CONFIG1 của bạn là dùng crystal ngoài 4MHz (thấy define là 4MHz) à? Có nhầm lẫn gì ko? 4MHz thì bằng xung nội xài thạch anh làm chi?
          • duong_act
            • Nov 2008
            • 4903
            Nguyên văn bởi chanhmuoi Xem bài viết
            #include dùng để khai báo sử dụng tên file header ( chứa các định nghĩa, tên hàm ... ) mà sẽ cần phải dùng.
            Nếu không cần đến header thì không nên include nó, vừa gây chậm biên dịch + không có tác dụng + có thể gây lỗi không mong muốn.
            2 cái cuối không dùng nên không include, cái thứ 1 và thứ 2 chỉ dùng 1 cái ( cái xc.h không nên dùng ).
            • htc2k14
              • Oct 2014
              • 279
              Vì sao ko nên dùng xc.h vậy bạn?
              • htc2k14
                • Oct 2014
                • 279
                #8
                • chanhmuoi
                  • Mar 2014
                  • 10
                  #9
                  Nguyên văn bởi htc2k14 Xem bài viết
                  Em dùng bộ dao động thạch anh, do em xem mấy video trên youtube đa số dùng bộ dao động ngoại nên e dùng theo, chứ chưa hiểu sâu, anh có tài liệu vi xử lí gì hay share qua mail cho e với, e đang tự học.
                  mail: anhvan1608@gmail.com
                  chanhmuoi Tìm hiểu thêm về chanhmuoi
