xem giúp em code sai chỗ nào
  • ozonedark2
    • Sep 2008
    • 267
    em nạp vô nhưng ko thấy led sáng chữ chạy mong các bác xem giúp em làm sai chỗ nào với
    #include <mega8.h>
    #include <delay.h>
    // SPI functions
    #include <spi.h>
    #define SCK PORTB.5
    #define DATA PORTB.3
    #define SCL PORTB.0
    #define A PORTC.0;
    #define B PORTC.1;
    #define C PORTC.2;
    #define OutEn PORTC.3;
    unsigned char Pattern1[8]={0,1,2,3,4,5,6,7};
    unsigned char flash chu_c[]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, 60,126,195,195,255,195,195,0};
    unsigned char DMem[8]; // Bo nho man hinh, 3 byte dau cho hang 1, 3 byte tiep theo cho hang 2 ...
    unsigned char i=0,rr,r=0;
    unsigned char k;
    void LatchData()
    SCL=0;
    SCL=1;
    // Timer1 output compare A interrupt service routine
    interrupt [TIM1_COMPA] void timer1_compa_isr(void)
    // Place your code here
    //spi(DMem[r*3+2]);
    //spi(DMem[r*3+1]);
    spi(DMem[r]);
    PORTC.3=1;
    LatchData();
    PORTC=Pattern1[r];
    PORTC.3=0;
    r++;
    if (r==8)
    r=0;
    // Declare your global variables here
    void main(void)
    PORTB=0x00;
    DDRB=0x2D;
    PORTC=0x00;
    DDRC=0x7F;
    PORTD=0x00;
    DDRD=0x00;
    TCCR0=0x00;
    TCNT0=0x00;
    // Timer/Counter 1 initialization
    // Clock source: System Clock
    // Clock value: 15.625 kHz
    // Mode: CTC top=OCR1A
    // OC1A output: Discon.
    // OC1B output: Discon.
    // Noise Canceler: Off
    // Input Capture on Falling Edge
    // Timer1 Overflow Interrupt: Off
    // Input Capture Interrupt: Off
    // Compare A Match Interrupt: On
    // Compare B Match Interrupt: Off
    TCCR1A=0x00;
    TCCR1B=0x09;
    TCNT1H=0x00;
    TCNT1L=0x00;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x00;
    OCR1AL=0x25;
    OCR1BH=0x00;
    OCR1BL=0x00;
    ASSR=0x00;
    TCCR2=0x00;
    TCNT2=0x00;
    OCR2=0x00;
    MCUCR=0x00;
    TIMSK=0x10;
    UCSRB=0x00;
    ACSR=0x80;
    SFIOR=0x00;
    ADCSRA=0x00;
    // SPI initialization
    // SPI Type: Master
    // SPI Clock Rate: 250.000 kHz
    // SPI Clock Phase: Cycle Half
    // SPI Clock Polarity: Low
    // SPI Data Order: MSB First
    SPCR=0x54;
    SPSR=0x00;
    TWCR=0x00;
    #asm("sei")
    //for (i=0;i<=7;i++)
    //DMem[i]=~chu_c[i];
    while (1)
    for (k=0;k<=7;k++)
    DMem[k]=~(chu_c[i*8+k]>>rr);
    rr++;
    if (rr==8)
    rr=0;
    i++;
    if (i==3) i=0;
    delay_ms(100);
  • aaahhhh
    • Aug 2009
    • 123
    anh tính đánh đố mọi ng à, mọi ng ko phải thầy bói đâu, ko có sơ đồ biết mạch này làm j????????????
    • queduong
      Moderator
      • Jul 2005
      • 6781
      sao lại có cả hàm trong hàm ngắt thế kia ? , lập trình tối kỵ hàm trong hàm ngắt đó ... nó thành đệ quy thì chip treo giẫy đành đạch !
      • ozonedark2
        • Sep 2008
        • 267
        #4
        Nguyên văn bởi aaahhhh Xem bài viết
        dạ em quên không nói em lập trình cho led ma trận 8x8 dùng 74138 quét hàng, 74595 đưa dữ liệu ra cột em làm chỉ 1 con ma trận 8x8 thôi
        • ozonedark2
          • Sep 2008
          • 267
          #5
          cái hàm spi(DMem[r]); này đúng không anh, tại em thấy bên anh nghaiha ở luồng tutorial-led-ma-tran-bang-hinh-anh-completed làm được nên em dùng
          • ozonedark2
            • Sep 2008
            • 267
            #6
            em lập trình bằng codevisionavr đó mấy anh
            • hoanganh1991
              Thành viên mới
              • Apr 2013
              • 5
              #7
              cái của anh nghĩa hà có thể phải mua cái mudel p10 hoặc tính toán lại mạch viết theo anh ấy là ko chạy,có ai đã nói làm theo cách của anh ấy chạy đâu topic đó theo mình chỉ là cách hướng dẫn lập trình thôi,bạn hiểu thuật toán quét led ma trận rùi tự làm cái mạch theo ý của bạn xem sao,mình đọc tpic của anh nghĩa hà lâu rùi nhưng ko thấy ai gủi video hay hình ảnh theo cách của anh ấy các video có trong topic đó đều là do mọi người làm theo cá nhân mình,bạn cứ dùng thuật toán đơn giản ko cần SPI đâu
              • ozonedark2
                • Sep 2008
                • 267
                #8
                Nguyên văn bởi hoanganh1991 Xem bài viết
                em làm giống anh nghaiha và đã chạy nên em muốn phát triển thêm phần chữ chạy , em làm đc chữ "A" chạy từ phải qua trái rồi nhưng đến khi em tăng lên muốn cho chạy nhiều chữ thì gặp vấn đề nên em muốn hỏi mấy anh trên diễn đàn
                ozonedark2 Tìm hiểu thêm về ozonedark2
