LẬP TRÌNH CHO lcd VÀ DS12887.....
  • LẬP TRÌNH CHO lcd VÀ DS12887.....
    MÌNH MỚI TẬP TÀNH LẬP TRÌNH VI ĐIỀU KHIỂN, NHỜ CÁC BẠN TEST HỌ CHƯƠNG TRÌNH NÀY XEM CÓ VẤN ĐỀ J KO NHÉ.CẢM ƠN CÁC BẠN NHIỀU NHIỀU!THANKS
    #include <Sfr51.inc>
    ;Chuong trinh hien thi dong ho so tren LCD 16x2 su dung DS12c887
    rs bit p2.7
    rw bit p2.6
    e bit p2.5
    t2 equ 2
    d equ 0ah
    settime bit p3.0
    up bit p3.1
    org 00h
    ljmp main
    ;chuong trinh con tao tre
    delay:
    mov tmod,#01h
    mov th0,#high(-1800)
    mov tl0,#low(-1800)
    setb tr0
    jnb tf0,$
    clr tf0
    clr tr0
    ret
    ;chuong trinh con tao tre 5ms
    delay5ms:
    mov r0,#5
    loop:
    acall delay
    djnz r0,loop
    ret
    ;chuong trinh con tao tre 50ms
    delay100ms:
    mov r0,#100
    loopp:
    acall delay
    djnz r0,loopp
    ret
    ;chuong trinh con LCD o che do nhan lenh
    nhanlenh:
    push acc
    clr rs ;dat LCD o che do nhan lenh
    clr rw
    setb e ;cho phep hien thi
    mov p1,a ;dua du lieu ra P1
    nop
    clr e
    pop acc
    acall delay5ms
    ret
    ;chuong trinh con LCD o che do nhan so
    nhanso:
    push acc
    setb rs ;dat LCD o che do nhan lenh
    clr rw
    nop
    clr e
    clr a
    pop acc
    acall delay5ms
    ret
    ;chuong trinh con nhan du lieu va hien thi cac chu cai
    nhanchu:
    push 1
    push acc
    loop9:
    setb rs
    clr rw
    setb e
    clr a
    movc a,@a+dptr
    mov p1,a
    nop
    nop
    nop
    clr e
    acall delay5ms
    inc dptr
    djnz r1,loop9
    pop acc
    pop 1
    ret
    ;chuong trinh con thiet lap cho LCd
    kdlcd:
    acall delay100ms ;cho Vcc dat dc gia tri dinh muc
    mov a,#38h ;hien thi 2 dong - co chu 5x7
    acall nhanlenh
    acall delay5ms
    mov a,#0fh ;
    acall nhanlenh
    acall delay5ms
    mov a,#0fh ;
    acall nhanlenh
    acall delay5ms
    mov a,#06h ;con tro tu dong tang
    acall nhanlenh
    ret
    ;chuong trinh con khoi dong RTC
    kdrtc:
    push 0
    push acc
    mov a,#0a0h
    mov r0,#0ah
    movx @r0,a
    mov a,#02h
    mov r0,#0bh
    movx @r0,a
    pop acc
    pop 0
    ret
    ;chuong trinh con dat gia tri dau cho RTC la 23:59:59 01(Sunday) 01/01/08
    ghirtc:
    push 0
    push acc
    mov a,52h ;dat giay
    mov r0,#0h
    movx @r0,a
    mov a,59h ;dat giayalarm
    mov r0,#1h
    movx @r0,a
    mov a,51h ;dat phut
    mov r0,#2h
    movx @r0,a
    mov a,58h ;dat phutalarm
    mov r0,#3h
    movx @r0,a
    mov a,#50h ;dat gio
    mov r0,#4h
    movx @r0,a
    mov a,57h ;dat gioalarm
    mov r0,#5h
    movx @r0,a
    mov a,#53h ;thu
    mov r0,#6h
    movx @r0,a
    mov r0,#54h ;ngay
    movx @r0,a
    mov r0,#55h ;thang
    movx @r0,a
    mov a,#56h ;nam
    mov r0,#09h
    movx @r0,a
    pop acc
    pop 0
    ret
    ;chuong trinh con doc gia tri tu rtc vao ram onchip
    ;23:59:59 vao 50h:51h:52h
    ;thu may vao 53
    ;01/01/08 vao 54:55:56h
    ;alarm vao 57:58:59h
    docrtc:
    push 0
    push acc
    mov r0,#0h
    movx a,@r0
    da a
    mov 52h,a
    mov r0,#2h
    movx a,@r0
    da a
    mov 51h,a
    mov r0,#4h
    movx a,@r0
    da a
    mov 50h,a
    mov r0,#6h
    movx a,@r0
    da a
    mov 53h,a
    mov r0,#7h
    movx a,@r0
    da a
    mov 54h,a
    mov r0,#8h
    movx a,@r0
    da a
    mov 55h,a
    mov r0,#9h
    movx a,@r0
    da a
    mov 56h,a
    pop acc
    pop 0
    ret
    ;chuong trinh con xuat thoi gian, thu ngay thang nam ra lcd
    htthu:
    push 0
    push acc
    push dpl
    push dph
    osat:
    mov a,53h
    cjne a,#00,osun
    mov r0,#3
    mov dptr,#sun
    acall nhanchu
    ret
    osun:
    cjne a,#01,omon
    mov r0,#3
    mov dptr,#mon
    acall nhanchu
    ret
    omon:
    cjne a,#02,otue
    mov r0,#3
    mov dptr,#tue
    acall nhanchu
    ret
    otue:
    cjne a,#03,owen
    mov r0,#3
    mov dptr,#wen
    acall nhanchu
    ret
    owen:
    cjne a,#04,othu
    mov r0,#3
    mov dptr,#thu
    acall nhanchu
    ret
    othu:
    cjne a,#05,ofri
    mov r0,#3
    mov dptr,#fri
    acall nhanchu
    ret
    ofri:
    cjne a,#06,osat
    mov r0,#3
    mov dptr,#sat
    acall nhanchu
    pop dph
    pop dpl
    pop acc
    pop 0
    ret
    ;hien thi ngay
    htngay:
    mov a,#0c5h
    acall nhanlenh
    mov a,54h
    anl a,#0fh
    add a,#30h
    acall nhanso
    mov a,#0c6h
    acall nhanlenh
    mov a,54h
    anl a,#0f0h
    add a,#30h
    acall nhanso
    ret
    ;hien thi thang
    htthang:
    mov a,#0c8h
    acall nhanlenh
    mov a,55h
    anl a,#0fh
    add a,#30h
    acall nhanso
    mov a,#0c9h
    acall nhanlenh
    mov a,55h
    anl a,#0f0h
    add a,#30h
    acall nhanso
    ret
    ;hien thi nam
    htnam:
    mov a,#0cbh
    acall nhanlenh
    mov a,56h
    anl a,#0fh
    add a,#30h
    acall nhanso
    mov a,#0cch
    acall nhanlenh
    mov a,56h
    anl a,#0f0h
    add a,#30h
    acall nhanso
    ret
    ;hien thi gio
    htgio:
    mov a,#85h
    acall nhanlenh
    mov a,50h
    anl a,#0fh
    add a,#30h
    acall nhanso
    mov a,#86h
    acall nhanlenh
    mov a,50h
    anl a,#0f0h
    add a,#30h
    acall nhanso
    ret
    ;hien thi phut
    htphut:
    mov a,#88h
    acall nhanlenh
    mov a,51h
    anl a,#0fh
    add a,#30h
    acall nhanso
    mov a,#89h
    acall nhanlenh
    mov a,51h
    anl a,#0f0h
    add a,#30h
    acall nhanso
    ret
    ;hien thi giay
    htgiay:
    mov a,#8bh
    acall nhanlenh
    mov a,52h
    anl a,#0fh
    add a,#30h
    acall nhanso
    mov a,#8ch
    acall nhanlenh
    mov a,52h
    anl a,#0f0h
    add a,#30h
    acall nhanso
    ret
    ;chuong trinh con hien thi thoi gian thuc
    hienthi:
    acall htcon
    acall htthu
    acall htngay
    acall htthang
    acall htnam
    acall htgiay
    acall htphut
    acall htgio
    ret
    ;chuong trinh con test phim 1
    test:
    jnb settime,setthu
    ret
    setthu:
    acall htthu
    jb up,$
    inc 53h
    acall htthu
    jb settime,setthu
    setngay:
    acall htngay
    jb up,$
    inc 54h
    acall htngay
    jb settime,setngay
    setthang:
    acall htthang
    jb up,$
    inc 55h
    acall htthang
    jb settime,setthang
    setnam:
    acall htnam
    jb up,$
    inc 56h
    acall htnam
    jb settime,setnam
    setgio:
    acall htgio
    jb up,$
    inc 50h
    acall htgio
    jb settime,setgio
    setphut:
    acall htphut
    jb up,$
    inc 51h
    acall htphut
    jb settime,setphut
    ljmp main1
    ret
    ;chuong trinh con hien thi constan
    htcon:
    mov a,#87h
    acall nhanlenh
    mov a,#3ah
    acall nhanso
    mov a,#8ah
    acall nhanlenh
    mov a,#3ah
    acall nhanso
    ret
    ;chuoi ky tu can hien thi
    org 200h
    sun: db "sun"
    mon: db "mon"
    tue: db "tue"
    wen: db "wen"
    thu: db "thu"
    fri: db "fri"
    sat: db "sat"
    ;chuong trinh chinh
    org 700h
    main:
    mov r0,#9
    mov r1,#40 ;bo dem cho ctc tao tre 40ms
    mov r2,#250 ;bo dem cho ctc tao tre 1s
    mov r3,#100
    mov sp,#60h
    acall kdlcd
    acall kdrtc
    acall htcon
    main1:
    acall ghirtc
    acall docrtc
    acall hienthi
    acall test
    sjmp main1
    end
sonngoc Tìm hiểu thêm về sonngoc
