a gửi cả file lên cho e dk không
[Share-code] Mỗi ngày một bài tập về AT89S52
mình có cái này này. k nhớ tác giả nhéNguyên văn bởi hoanganh234 Xem bài viếta gửi cả file lên cho e dk không
Code:#include <REGX51.H> unsigned char preloadTH=0xFF,preloadTL=0xFF; unsigned int pointer=0,ii=0,jj; sbit out=P2^0; //octa: 0 //key : C C# D D# E F F# G G# A A# B code float key_octa0[]={16.35,17.32,18.35,19.45,20.6,21.83,23.12,24.5,25.96,27.5,29.14,30.87}; code unsigned int chuan=1000; code float crystal=11.0592; //music code unsigned char music[]= { "4d~,4d~,3g~,3a~,4d.,4d~,4g~,4a~,4b~,4a=,4g=,4d.,4 e~,3a~,4c~,3g~,3a~,4d~,4d ,4d=,4c=,3a~,4c~,3g~,3a~,4do" "4g~,4g~,4d~,3a~,4g.,4g~,4a~,4g~,4b=,4a=,4g~,4d.,4 g~,4e ,4e~,4d~,4c ,4d~,4d~,3a~,4d~,3b~,3a~,3go,4d ,4go" "4go,4a ,4b~,4a~,4F~,4g.,4d~,4g~,4a~,4a=,4b=,4a~,4g.,4d~,3 a ,3a ,3a~,4d ,4d~,4d ,3a=,3b=,3a~,3g.,4b=,4a=" "4g~,4d~,4g~,4d~,3a.,4g~,4g ,4F~,4a~,5d.,4a=,4b=,4d ,3a ,4go,4d~,4d~,3g~,3a~,4do,4g~,4g~,4d~,3a~,4go,4g~" "4d~,4g~,4a~,4A ,4a~,5d~,4b~,4a~,4g~,4F~,4g ,4d ,4d ,4g~,4a~,4A ,4a~,5d~,4b~,4a~,4g~,4F~,4go,s" }; void doitanso(float tanso) { unsigned int giatrinap; giatrinap=65536-(unsigned int)((1000000*crystal)/(24*tanso)); preloadTL=(unsigned char)giatrinap; preloadTH=(unsigned char)(giatrinap>>8); } void key(unsigned char octa,unsigned char k) { float tanso; switch (k) { case 'c' : tanso=key_octa0[0]; break; case 'C' : tanso=key_octa0[1]; break; case 'd' : tanso=key_octa0[2]; break; case 'D' : tanso=key_octa0[3]; break; case 'e' : tanso=key_octa0[4]; break; case 'f' : tanso=key_octa0[5]; break; case 'F' : tanso=key_octa0[6]; break; case 'g' : tanso=key_octa0[7]; break; case 'G' : tanso=key_octa0[8]; break; case 'a' : tanso=key_octa0[9]; break; case 'A' : tanso=key_octa0[10]; break; case 'b' : tanso=key_octa0[11]; break; } switch (octa) { case '1' : tanso*=2; break; case '2' : tanso*=4; break; case '3' : tanso*=8; break; case '4' : tanso*=16; break; case '5' : tanso*=32; break; case '6' : tanso*=64; break; case '7' : tanso*=128; break; case '8' : tanso*=256; break; } doitanso(tanso); } unsigned int trave(unsigned int ms) { unsigned int a; a=preloadTH; a=a<<8|preloadTL; return (ms*crystal*1000)/12/(65536-a); } unsigned int tempo(unsigned char tem) { switch (tem) { case '=' : return trave(chuan); break; case '~' : return trave(chuan*2); break; case ' ' : return trave(chuan*4); break; case '.' : return trave(chuan*6); break; case 'o' : return trave(chuan*8); break; } } void ngattimer_0(void) interrupt 1 { out=~out; TL0=preloadTL; TH0=preloadTH; if(ii==0) { if(music[pointer]=='s') TR0=0; key(music[pointer],music[pointer+1]); jj=tempo(music[pointer+2]); } ii++; if(ii==jj) { ii=0; pointer+=4; } } void main(void) { P0=P1=P2=P3=0; /*TMOD=17; TL0=0xff; TH0=0xff; ET0=1; EA=1; TR0=1;*/ EA=0; TMOD=0x02;// 8 BIT AUTO RELOAD TL0=0xff; TH0=0xff; ET0=1; EA=1; TR0=1; while(1); }Nguyễn Huy Biên - 01649 802 694
gmail :
a có hướng dẫn tạo tần số bài hát cho e vớiNguyên văn bởi bienhou Xem bài viếtmình có cái này này. k nhớ tác giả nhé
bạn chịu khó serach có 1 topic trong luồng này bàn về vấn đề này rồi nhéNguyên văn bởi hoanganh234 Xem bài viếta có hướng dẫn tạo tần số bài hát cho e vớiNguyễn Huy Biên - 01649 802 694
gmail :
e tìm rồi nhưng chẳng hiểu làm thế nào để tạo ra code jinglebell như của chjpchjp1991 vậyNguyên văn bởi bienhou Xem bài viếtbạn chịu khó serach có 1 topic trong luồng này bàn về vấn đề này rồi nhé
rất cám ơn bạn đã up những bài hay thế này. Đối với mình, những bài như thế này giúp mình có thể hiểu và áp dụng ngày càng nhuần nhuyễn hơn từ kiến thức của C++ vào việc lập trình cho vi điều khiển. Từ đó phát triển thêm các dạng bài tập mà bạn đưa.
Ngoài ra, bạn có thể gửi mình 1 số tài liệu giáo trình về lập trình C cho 8051 được không ? Mail mình là malphite1993@yahoo.com
Cám ơn nhiều!!!
hay quá đúng cái em đang cần
PK ! $çéü Ä [Content_Types].xml ó (á ┤öMOâ@ å∩&■▓W █z0╞ö÷á⌡¿M¼±╝.C┘╚~dg√⌡∩ JK¬íÑZ╜É└2∩√╠
3â╤Jù╤ <*kR╓Oz, #mª╠,e»╙╟°ûE ä╔Di
ñl
╚F├╦ï┴tφ #¬6ÿ▓" w╟9╩ ┤└─:0tÆ[»Eá[?πN╚ 1 ~▌δ▌piM ΓPi░ßα r1/C4^╤πÜ─Cë,║»_¼╝R&£+ò üHTổng thống + điện = Ăn mày + điện = die => Tổng thống = ăn mày
ặc lỗi font rồi .viết tay vậy .
Đề: chân ngắt của vi điều khiển dc nối với 1 nút nhấn .mỗi khi nhấn tạo ra sự thay đổi trạng thái của vdk .(từ mức cao xuống mức thấp)
chân p2.0 dc nối vs 1 con led đơn
Yêu cầu :
khi nhấn nút (sử dụng ngắt int0) thì đèn sẽ sáng nhấp nháy 3 lần với chu kì là (1s sáng 1s tối)Tổng thống + điện = Ăn mày + điện = die => Tổng thống = ăn mày
bạn nên tạo 1 nhãn chương trình con delay 1s, mỗi lần sáng tắt thì gọi, chươnng trình dành cho ngắt của bạn rắc rối quáNguyên văn bởi hoangthuanhd Xem bài viếtặc lỗi font rồi .viết tay vậy .
Yêu cầu :
sbit khai báo địa chỉ của một bit đó bạn. Ví dụ: Port 0 địa chỉ của nó là 0x80. Thay vì phải set nguyên một Port 0 mỗi lần muốn điều khiển một pin thì bạn khai báo của địa chỉ của pin đó:Nguyên văn bởi malphite1993 Xem bài viếtcho mình hỏi lệnh sbit trong c ý nghĩa và mục đích là gì vậy? vì hồi đó giờ toàn dùng define hoặc dùng trực tiếp port luôn nên thấy cái sbit lạ lắm
hoặcCode:sbit P0_1 P0^2 //thường trong header của keilc dùng dạng này
Code:sbit P0_1 0x81 //địa chỉ cụ thể của bit trong special function registers
cho mình hỏi chút xíu về cái 89s52 này, mình nạp qua isp nhưng khi ko cắm led + trở vào chân p0.1 thì ok. còn khi mà đề led + trở nối p0.1 là báo lỗi chip k nạp được. Mình dùng progisp.
ai biết về vụ này cho mình lời khuyên vs.
Chân reset mình nối 1 con 104 xuống đất luôn có ok không ?, vì nạp thấy nó vẫn chạy đều mà xem trên net thì thấy còn cần trở 10k nữa
02-05-2026, 21:23 -
27-04-2026, 17:00 -
Trả lời cho Yêu thơ mê nhạc, mời các bác vào đây!bởi dinhthuong92Bài này cháu phải "Creat" trên 30 lần rồi cắt ghép mới tạm có hồn tí đó bác. Quá nản luôn!!!
HẸN ƯỚC XUÂN SANG
Sáng tác: Hoàng Đình Thường
Hòa âm & hát: Suno AI
---25/04/2026----
[Verse 1]
Gió...-
25-04-2026, 11:05 -
