Như tít , em đang dùng đt , mọi người giúp em với , em cảm ơn
Có phần mềm nào trên android giống altium proteus trên máy tính không mọi người
Nguyên văn bởi thewolf Xem bài viếtngây thơ quá cháu ơi =)) phần mềm của ngta mười mấy GB chạy test quạt tản hú rầm rầm mà e đòi chạy trên android là cớ làm sao
Cái này được khôngPCB Droid provides an easy way to design your printed circuit boards for your electronic DIY projects. It can be an extension hardware for your raspberry PI or arduino panel, or even a printed circuit board for the drone or 3d printer you designed. Create your custom PCBs on your mobile and on your tablet fast and efficiently. Share and export your finished designs. Save time by working on your projects during your daily commute, no matter where you are. PCB Droid’s easy to use experience makes the application the perfect choice for electronic hobbyists and also a great designer tool for education purposes. The application doesn’t utilize previously made circuit diagrams. Draw your lines, place your through holes and SMD pads the way you want to. Download the available macros to help your designing process or create your own and use them later on. Log in with your own PCB Droid account or use your Gmail account and start customizing your circuit boards as you wish! If you are having trouble using the application, check out our official tutorial on our website. http://pcbdroid.com/tutorials/ Features: -Design double-sided PCBs, switch between layers, hide the unnecessary layers for improved transparency -Expanding downloadable component library -Create and save your own macros -Share your finished printed circuit boards with your friends/colleagues -Export your projects to PDF, IMG or GERBER format -Reach your project from multiple devices with droid cloud integration Download now and send us your feedbacks and questions to support@pcbdroid.com or http://pcbdroid.com/contact-us For more information visit http://pcbdroid.comHưng yên
Mấy cái đấy để làm cảnh thôi . Chỉ nối được vài cái pad .
Vẽ xong , ngoài cái máy android đó ra , các máy tính khác , các phần mềm khác đều không hiểu gì . Thua luôn , Không thể tách các layout , tách ra các file để in , để khoan , cắt , phay ...
Chỉ gọi là PHÁC THẢO Ý TƯỞNG thôi .Chuyên làm các mạch điện tử bí hiểm và kỳ quặc .
nguyendinhvan1968@gmail.com
Hôm qua, 21:02 -
Hôm qua, 20:37 -
Hôm qua, 10:53 -
Hôm qua, 05:06 -
Quán ăn Vĩnh Yên-
25-04-2024, 21:56 -
Nhà hàng Vĩnh Yên-
25-04-2024, 21:50 -
bởi chinhnguyen9Vai viết này đã được chuyển sang chuyên mục phù hợp....
25-04-2024, 08:29 -
bởi chinhnguyen9
Xem hình có phần thuyết minh bên trong tiện việc quan sát và đọc thuyết minh. Khi G1 high dòng điện chạy theo các đường màu đen khi G2 high dòng điện chạy theo các đường màu nâu đỏ.
Bổ sung một tính chất củng cố cho tên gọi tụ...-
24-04-2024, 01:15 -
23-04-2024, 19:24 -
23-04-2024, 16:05 -
