ah. mình hiểu rùi. nhưng cho mình hỏi tại sao lại mắc như vậy mà ko phải là vcc----> led---> uln2803---> trở---> VDK
Làm bảng quảng cáo Led
bien_x equ 50h
lap:
mov p1,#10001000b
call tre
mov p1,#01000100b
call tre
mov p1,#00100010b
call tre
mov p1,#00010001b
call tre
mov p1,#10001111b
call tre
mov p1,#01000000b
call tre
mov p1,#00101111b
call tre
mov p1,#00010000b
call tre
mov p1,#10001111b
call tre
mov p1,#01000000b
call tre
mov p1,#00101111b
call tre
mov p1,#00010000b
call tre
mov p1,#10001111b
call tre
mov p1,#01001111b
call tre
mov p1,#00101111b
call tre
mov p1,#00011111b
call tre
mov p1,#10001111b
call tre
mov p1,#01001111b
call tre
mov p1,#00101111b
call tre
mov p1,#00011111b
call tre
mov p1,#00010001b
call tre
mov p1,#00100010b
call tre
mov p1,#01000100b
call tre
mov p1,#10001000b
call tre
mov p1,#00011111b
call tre
mov p1,#00100000b
call tre
mov p1,#01001111b
call tre
mov p1,#10000000b
call tre
mov p1,#00011111b
call tre
mov p1,#00100000b
call tre
mov p1,#01001111b
call tre
mov p1,#10000000b
call tre
mov p1,#00011111b
call tre
mov p1,#00101111b
call tre
mov p1,#01001111b
call tre
mov p1,#10001111b
call tre
mov p1,#00011111b
call tre
mov p1,#00101111b
call tre
mov p1,#01001111b
call tre
mov p1,#10001111b
call tre
mov p1,#00011111b
call tre
mov p1,#00101111b
call tre
mov p1,#01001111b
call tre
mov p1,#10001111b
call tre
jmp lap
TRE:
MOV R5,#3
N3: MOV R6,#200
N2: MOV R7,#200
N1: DJNZ R7,N1
DJNZ R6,N2
DJNZ R5,N3
RET
end
bien_x equ 50h
lap:
mov p0,#11111111b
mov p2,#00111111b
mov p3,#00000100b
call tre
mov p0,#00000111b
mov p2,#00000000b
mov p3,#00001000b
call tre
mov p0,#00111000b
mov p2,#00000000b
mov p3,#00010000b
call tre
mov p0,#11000000b
mov p2,#00000111b
mov p3,#00100000b
call tre
mov p0,#00000000b
mov p2,#00111000b
mov p3,#01000000b
call tre
mov p0,#11000000b
mov p2,#00000111b
mov p3,#10000000b
call tre
mov p0,#00111000b
mov p2,#00000000b
mov p3,#01000000b
call tre
mov p0,#00000111b
mov p2,#00000000b
mov p3,#00100000b
call tre
mov p0,#00111000b
mov p2,#00000000b
mov p3,#00010000b
call tre
mov p0,#11000000b
mov p2,#00000111b
mov p3,#00001000b
call tre
mov p0,#00000000b
mov p2,#00111000b
mov p3,#00000100b
call tre
mov p0,#00000111b
mov p2,#00111000b
mov p3,#00001000b
call tre
mov p0,#00111000b
mov p2,#00111000b
mov p3,#00010000b
call tre
mov p0,#11000000b
mov p2,#00111111b
mov p3,#00100000b
call tre
mov p0,#11000111b
mov p2,#00111111b
mov p3,#01000000b
call tre
mov p0,#11111000b
mov p2,#00111111b
mov p3,#10000000b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#01000000b
call tre
mov p0,#00000000b
mov p2,#00000000b
mov p3,#00100000b
call tre
mov p0,#00000000b
mov p2,#00111000b
mov p3,#00010000b
call tre
mov p0,#11000000b
mov p2,#00000111b
mov p3,#00001000b
call tre
mov p0,#00111000b
mov p2,#00000000b
mov p3,#00000100b
call tre
mov p0,#00000111b
mov p2,#00000000b
mov p3,#00001100b
call tre
mov p0,#00000111b
mov p2,#00111000b
mov p3,#00011100b
call tre
mov p0,#11000111b
mov p2,#00000111b
mov p3,#00111100b
call tre
mov p0,#00111111b
mov p2,#00000000b
mov p3,#01111100b
call tre
mov p0,#00111111b
mov p2,#00111000b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00000111b
mov p3,#00000000b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#00000111b
mov p2,#00111000b
mov p3,#10000100b
call tre
mov p0,#11111000b
mov p2,#00000111b
mov p3,#11001100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#00110000b
call tre
mov p0,#00000111b
mov p2,#00111000b
mov p3,#01111000b
call tre
mov p0,#11111111b
mov p2,#00111111b
mov p3,#11111100b
call tre
jmp lap
TRE:
MOV R5,#3
N3: MOV R6,#200
N2: MOV R7,#200
N1: DJNZ R7,N1
DJNZ R6,N2
DJNZ R5,N3
RET
end
ra đường thấy nhiều biển led quang cáo thấy đẹp mắt ...cố gắng làm 1 cái cho bằng anh bằng em mong các bác chỉ giáo em vài chiêu : mình có ra chợ nhật tảo tham khảo và mua dc bộ VDK EPROM 20 kiểu nháy 12v 16 cổng mỗi cổng mác nối tiếp từ 50 đến 70 led . nhưng khi mang về thì mình không bit cách mắc các bóng led và trở như thế nào
mình tính làm cái bảng quang cao có các chữ như sau : sửa chữa ĐTDĐ
các bác cho xin cái sơ đồ câu led nối tiếp ...mình dự tính 1 chữ mình mác khoang 14 led
p/s vì là dân ngoại đạo lên kiến thức điện tử của mình chỉ bàng hạt gạo
Nguyên văn bởi xuanohyes89 Xem bài viếtMình làm thế này các bạn xem thử đùng ko nhé
Và xem giúp mình con trở phân cực cho chân B đó dùng bao nhiêu là vừa???
Thân
Link down:
LUONG Y VU NGOC KET.pdf
Nguyên văn bởi vucongquantb Xem bài viếtBạn tham khảo sơ đồ mình làm nè. Mạch cho ra 16 cổng, xuất ra trên P1 và P3. Tầng kéo dòng cho Led dùng TIP41C và 74HC245. Nguồn 12VDC, 15A cấp cho LED, nguồn 5VDC cấp cho AT89C51.
Link down:
Boar bạn thiết kế sao ko thiết kế 32 cổng luôn, lúc đó mình muốn xài bao nhiêu thì xài. ( Góp ý đừng la)
Mình có cái mạch này chuyên bán cho bọn quảng cáo. Chưa cài PDF xuất ảnh này tạm. Có mạch in PT nè.89xx.rarPCCC
Nguyên văn bởi lep140389 Xem bài viếtBạn cấp tải j mà tới 15A thế bạn, Led công suất ah.
Mà làm như bạn mình nghĩ không được hay cho lắm, phải chăng khi muốn mạch hoạt động bạn phải làm thao tác cấp nguồn 2 lần(1 cho bo điều khiển 8051, 1 cho mạch hiển thị là bảng LED?) tại sao bạn không gộp cả 2 lại là 1, toàn mạch(khối nguồn, khối công suất, khối điều khiển) nằm trên 1 board luôn, đỡ phải chia ra làm nhiều board con.Last edited by vucongquantb; 02-01-2012, 14:18.
Link down:
LUONG Y VU NGOC KET.pdfĐT: 0972 20 58 68
Gmail:
Nguyên văn bởi vucongquantb Xem bài viếtừh, mình làm bảng quảng cáo lớn. Có một số người dùng hẳn nguồn máy tính, dùng như vậy phí quá, mà làm như mình tính ổn định cũng cao mà, dong ra cũng đâu thua kém gì. Mạch của bạn không có nút reset àh, làm như vậy thì không được hay cho lắm. Chẳng lẽ khi muốn reset lại rút nguồn cấp chính cho mạch ra rồi lại cắm lại?
Còn phần reset thì bạn đừng quan tâm làm j, mình cố ý làm vậy.PCCC
Nguyên văn bởi [VN]NMD Xem bài viếtBạn cho mình hỏi, có phải bạn dùng Tip41 k. Cho mình xin tên linh kiện luôn nha. Mình thấy 1 số bạn trên diễn đàn dùng thêm con 595 nữa, nhưng mạch của bạn không thấy ( mình mới vào nghề nên chưa rành) bạn giải thích giùm mình nha . mail mình: lvlyloves@yahoo.com
Nếu 1 cổng của bạn sử dụng chịu đựng đc công suất bao nhiêu thì nên gắn trans hoặc fet có công suất = hoặc lớn hơn.PCCC
bởi lamvu0677Chào mọi người, e làm trong cty về biến áp , toàn mấy con nhỏ nhỏ, làm sao để mình có thể kiểm tra nhanh số vòng dây của mỗi cuộn , đầu vào đầu ra của dây, có thiết bị gì nhỏ gọn hỗ trợ việc này không ạ , xin cảm ơn...
hôm nay, 07:15 -
Trả lời cho Yêu thơ mê nhạc, mời các bác vào đây!bởi vi van phamNhịp 2/4 1 trường canh có 2 nốt đen. Nhịp 3/4 1 trường canh có 3 nốt đen. Nhịp 4/4 1 trường canh có 4 nốt đen.
Các điệu nhạc sẽ có âm bass ở phách mạnh. Dồn 2 trường canh 2/4 thành 4/4 chơi điệu chachacha, nghe "kỳ cục" lắm....-
08-05-2024, 07:05 -
Trả lời cho Dùng MC34063 để làm driver lái led 1W, 3Wbởi bqvietDatasheet PT4115 có sẵn sơ đồ chuẩn, lắp theo đúng nó là xong. Mạch cực đơn giản luôn.
08-05-2024, 00:31 -
Trả lời cho Yêu thơ mê nhạc, mời các bác vào đây!bởi dinhthuong92Cháu có biết gì về nhịp 2/4 hay 4/4 đâu, hôm bữa hỏi chú nhạc sĩ kia nói là để 2/4 ạ....
07-05-2024, 21:47 -
Trả lời cho Yêu thơ mê nhạc, mời các bác vào đây!bởi vi van phamNhịp 4/4 người ta mới chọn điệu Chachacha. Cháu viết nhịp 2/4 thì 2 trường canh mới hoàn thành điệu chachacha. Khi đó sẽ có lúc không khớp với tiếng trống điệu chachacha. Thời gian hành âm nhanh 120 cháu nên chọn điệu disco sẽ hay hơn....
07-05-2024, 20:21 -
Trả lời cho Yêu thơ mê nhạc, mời các bác vào đây!bởi dinhthuong92Theo gợi ý của bác, cháu dịch xuống vài nốt đây:...
07-05-2024, 16:42 -
Trả lời cho Yêu thơ mê nhạc, mời các bác vào đây!bởi vi van phamHay quá dinhthuong ơi!
Tôi có sự góp ý nhỏ thế này:
1- Chachacha thường viết cho nhịp 4/4, ít thấy nhịp 2/4 lại là điệu Chachacha.
2- Đoạn Bao nhiêu yêu thương ......và điệp khúc bao nhiêu hân hoan..... cao quá làm sao ca sĩ hát nổi?...-
07-05-2024, 15:31 -
bởi chinhnguyen9Thú thật tôi lúng túng không biết nên gọi thế nào cho đúng nhất về dòng sản phẩm này.
Tham khảo trên AliExpress về dòng sản phẩm này, dù là hàng có thương hiệu họ cũng chưa có tên gọi khác. Ở VN có lẽ các shop muốn nhấn mạnh trong cách gọi để bộc...-
07-05-2024, 10:46 -
